Desert Sand
  • masuzzu
    • Aug 2008
    • 37
    Desert Sand
    Below is an excerpt from a website that discusses the insulation property of sand:
    "Temperatures in Namib can reach as high as 150 degrees on the surface of the sand. A fraction of an inch could mean a 30 degree temperature difference. The sand , as well as shade, act as insulators to the intense sunlight found in Namib Desert. "
    Assuming that the above is correct , can sand be used as an insulator below the hearth floor and on top of the dome (possibly in place of vermiculite)?
    Re: Desert Sand
    No. Deep sand in the desert stays cool because it conducts the cold from below. Caves are always 50 degrees. It's not remotely an insulator.
    • Johnny the oven man
      • Jun 2008
      • 399
      Re: Desert Sand
      The problem with sand as an insulation on top is if you get cracking, sand will get onto your meal you are cooking. V'lite is much coarser.
