fb blanket
  • sumu
    • Oct 2008
    • 100
    fb blanket
    FB Blanket do you think you can put pink insulation board down on harth then put the blanket on top and then put the oven floor on top of it ...
  • mfiore
    • Oct 2007
    • 919
    Re: fb blanket
    Sumu,
    The blanket is not designed to go underneath the oven. I would think it does not have the compressive strength. The FB board should go below. The blanket is designed to wrap around the oven. The pink stuff is not designed to handle the heat or weight of a brick oven.
    Mike - Saginaw, MI
    Picasa Web Album
    My oven build thread
