Hi,
I have placed Cal Sil boards (from Darley refractories OZ) directly onto the concrete hearth. There is no layer of vermiculite mix under the boards. The boards are 25mm (1") thick, 1000mm x 610mm and cost 50 bucks each. You need four to cover the dome site. I have been assured that this thickness is sufficient to insulate the oven floor (75mm/3")fire brick from the concrete hearth. Any thoughts on this?
