I know this issue has come up a thousand or more times on this forum, but I got ahead of myself a little bit and now I am in a bit of a bind. Prior to reading all of the posts here (until my eyes bleed), I had poured my slab and set my concrete block to a hearth size of 52" x 64". I will get back to this.
I know the dome circulates heat better and seems to have more usable space. I also understand it takes longer to heat up the vault because of the necessary cladding. I knew most of this from reading the forums before I started with the intention of the barrel vault style, but honestly, the extra time to heat up the vault would be worth it to us as we want to cook a lot of bread and other food in the oven. That, and the easy install of the vault is appealing as I am sure it is to a lot of people. Building that dome correctly looks to be much more difficult than the vault.
However, the more I read here the more I realize in the long run I would probably be happier with the Pompeii oven. The positives outweigh the negatives of the harder build. If all the other people can do it here, it can't be that hard. Right?
Problem is, I already have the hearth slab setup to be 52x64. I am building a house around mine with a roof. With a 36" inside diameter I figure I will need a minimum of 54" wide. 36" + 9" of FB(4.5 each side) + 2" for a 1" thick blanket on each side + 3.5" each side for the metal studs, gives me the 54". I would then just fill in the entire chamber, including the inside of the metal studs, with Perlite. I would have a minimum of 4.5" of insulation all the way around with the combo of blanket and Perlite.
The way I see it, I have a few options. (1) Build the hearth slab out an inch past the cement block on either side and deal with that problem when I go to finish it...(2) Build a smaller dome..or (3) build the barrel vault anyway and put the FB on their flat(2.5") for the bottom and only do 1-1.5" of cladding on the top and sides as a compromise for heat-up time.
Your opinions on this would be greatly appreciated.
Scott...
Scott...
