G'Day from a novice oven-builder in Australia! This is my first post on the forum- have been researching designs and decided to build a brick dome (as per FB). I have decided on an area in the yard- on ground that is retained by a wooden wall made from treated timber logs. The oven will be just above waist height. Plans describe a concrete base but I wonder whether a base of decomposed granite with sand on top is strong enough? I have wooden forms enclosing an area 1700 X 1300 for the oven.
Should the floor bricks be stable enough to hold up the oven?
I appreciate your advice.
Jona45
Jona45
