Re: Steel Dome Oven On A Trailer
Dave, the seal you designed around the chimney appears to be a vented clay piece? I can see how your seal would allow moisture to escape and also keep the rain out.
I think I could cut the masonry down a slight bit around my chimney ring - I have metal lath wrapped around the chimney ring to hold the plaster - by cutting the plaster down, there will be a small airspace where the metal lath is exposed...then maybe I could build a little metal hood around the ring above the cut to keep the rain out and still allow an escape route for trapped moisture. I'll have to mull this over.
Thanks a lot for your input.
G
G
