mixture of vermiculite
  • sumu
    • Oct 2008
    • 100
    so is this right 6 shoval fulls of vermiculite to 1 shoval full of portland cement then mix with water.and troll out.
  • exceloven
    • Aug 2008
    • 279
    Re: mixture of vermiculite
    I'm not sure what troll out means, but the proportions are correct.
    Mark
      You're going to find that vermiculite concrete is weird stuff, it's nothing like smoothing and floating concrete with conventional aggregates. You're going to use your trowel to pat it into place, the goal is to slightly compact the top surface, rather than draw a slurry of wet cement to the surface.
      • gjbingham
        • Sep 2007
        • 2021
        All in all though, your description sounds about right. I used a 5 to 1 ratio. Your's may work a bit better for its intended purpose.
        GJBingham
