Forno on a Trailer Q
  • southpaw
    • Apr 2005
    • 35
    hey all,
    Im planning to build an oven on a trailer (for catering and events) with a cooking surface diameter = 90 or 100cm with the following characteristics:
    1. Light overall weight (it should be as light as possible)
    2. Outer Size (should be as thin as possible)
    3. Reach pizza heat very fast ( and retains heat for a long time)
    Considering that, i have the following Q:
    - what is the cooking surface size (diameter) recommended? 90 - 100 - 110?
    - whats the minimum thickness of the hearth insulation? (regarding insulating heat effectively & keep the oven floor at the right temp)
    - is it possible to use the insulation ceramic blanket for the hearth & place the cooking surface directly on top? instead of vermiculite boards or vermiculite cement mix?
    - how thick should the cooking surface fire bricks be (minimum thickness)?
    - im thinking of using 3cm thick bricks.
    - how thick should the oven walls and dome fire bricks be (minimum thickness)?
    - do they have to be the same thickness as the oven cooking surface, or it doesn't matter?
    - what should the internal dome height be for each of 3 different sizes (90 - 100 - 110)
    - How thick should the thermal layer be for both the side walls and dome?
    - whats the minimum thickness of the dome insulation if im going to use the ceramic blanket?
    im going with an igloo design for the external covering
    * i came across this idea the other day, insulating the oven dome or even the hearth by using "HEAT CERAMIC INSULATION PAINT" with a layer thickness of around 10mm.
    - What do you thick, will it do the job?
    really appreciate your professional advice, comments and opinion on my idea and the listen questions.
    thanks all
