Before today I had fired my new oven 6 times with fires increasing in size each time, but never to the point where the ceiling turned white. Today, after installing the chimney I put in the first good sized fire. Everything worked well with the top 4 or 5 courses of the dome turning white, but the other courses staying black. I don't yet have my infrared thermometer so I don't know what the temperature rose to, but I do know it was HOT. I tried the 1 Mississippi, 2 Mississippi approach but I didn't get past the 1 Miss....
After about an hour and a half I noticed that there was some smoke coming out from some new cracks. Holy smoke!
What should I do about this issue. I haven't yet closed in the dome so do have access for some repair which I presume I have to do. Should I just slather on some more mortar, or should I use a crack fixer, or what?
Any suggestions would be much appreciated.
Thanks,
Davy
Thanks,
Davy
