Weatherproofing
  • Abear
    Re: Weatherproofing
    How about an underlayment of heavy plastic between two layers of dome covering (cement, vermicrete or stucco)?
  • Neil2
    Re: Weatherproofing
    No stucco, even acrylic stucco is water proof. Acrylic stucco is "water resistant". This is fine for light rain.
    During the rainy season (October to May here on Vancouver island) I cover mine with a sheet of plastic when not in use.
  • Abear
    Re: Weatherproofing
    Originally posted by Cypress View Post
    I will be putting on a multi layer stain then seal. Where did you get your stucco here in Houston?
    I got the base stucco from Home Depot in one of their broken bag pallets. Planned on using it since I had it - no experience with stucco, though. I was planning on building up the sides and dome with formed vermicrete using mesh for support. Then apply the base stucco on the porous vermicrete surface. Would that work or would I have to affix some diamond mesh?
  • mfiore
    Re: Weatherproofing
    Dick, which masonry parts are you concerned about? The cultured stone face? counter? firebrick? decorative arch? I live a few hundred miles north of you. I was planning the oven to be winter proof. I really don't want to cover it every winter (plus, I plan to use it in the winter, too!)
  • Cypress
    Re: Weatherproofing
  • thebadger
    Re: Weatherproofing
    You'll probably need to paint it with a masonry or stucco paint. I think you'll be fine keeping the water out. The one thing I did last year is I left my oven exposed all winter (in Ohio). I don't think I"ll do that again this year. I think the freeze thaw cycles are hard on the exposed masonry portions of my oven..
    Dick
  • Abear
    started a topic Weatherproofing
    Weatherproofing
    Quick question as I change plans yet again...if I cover my oven with a layer of vermicrete then stucco, will it keep the water out?
