I've been researching outdoor oven construction but did not want to use either brick, adobe or cement....
But since I've baked in terracotta flower pots I began to consider my options using that resource.
This example got me thinking:
But it's a bit small. So I thought it through -- and wondered...
What if I used two large terracotta flower pots of the same lip circumference. I cut a upside down U opening in the bottom of one for a door opening and butted the two pots at their lip together horizontally. Now butted together, I'd support and embed them in a base of sand medium so that they were in the one horizontal plane and joined the two lips together (with?) -- something like a large squat clay cocktail shaker on its side.
I'd build up the floor horizontally inside the pot oven (with clay?sand?) and lay down a cooking slate on top of that..
Voila! One terracotta oven.
A variation would be to coat the inside of each pot before I joined them with a layer of clay to increase the oven's insulation properties and maybe reduce its depth if necessary. I usually sculpt in paper clay and that may do the trick as I never fire it when I've made puppets.
No matter because the exterior is already fired terracotta the inner layer would be protected from weathering. It would be like a tandori oven on its side but not as narrow.
The exterior look would be snazzy terracotta.
One issue: would this work? All of it? Only part? None?
Additions:
In my experience working fired terracotta is facilitated by soaking the pots in water before cutting and trimming.
Additions:
- some constructed support for the doorway as the terracotta opening may become brittle and crack when knocked by tools and gear passing through.
- a little chimney hole towards the front -- made as a second opening cut in the pot either toward the top of the base or along the side wall of the front flower pot
- Door? Use a terracotta pot saucer made for the pot size and cut across a tangent so it sat snugly overthe opening.(I could also cut an arch in a saucer to support and strengthening my oven doorway too using the saucer rim as arch support)
