Tarracotta Flower Pot Oven -- using two flower pots
  • #16
    Re: Tarracotta Flower Pot Oven -- using two flower pots
    could you make pieces from clay, dry them and fire them in the brick oven?
    i got my oven hot enough to melt wine bottles. would that be enough to shrink and provide some level of firing?
    christo
    My oven progress -
    sigpic
    • #17
      Hey Christo,,,,
      Did you melt the wine bottles on purpose ??? or were they just tooo close, ???
      Mark
      • #18
        Clay undergoes the irreversible change at 573 C so that it won't return to mud if water is added. Glass usually melts at around 900C but every glass is different, artists who do glass slumping test each glass they use. Some even have a plastic content which makes them melt at an even lower temp.
        • #19
          Man i've been thinking on this option for a while, i used to have a fireplace made of terracota and worked just fine, i'll try it and add the insulation layer outside and not inside. i'll kepp you all posted .
