Concrete for the hearth slab.
  • I burnt my fingers
    • Jul 2009
    • 19
    Hi all,
    I?m new to the forum and am building a Wood fired oven. My question is about the floating concrete slab and the fire bricks.
    What concrete should be used? Refractory or ordinary concrete for the floating slab?
    I?ve been told that the fire bricks provide little insulation and that the heat transfer to the concrete through the fire bricks would make the aggregate in the concrete explode. Is there any truth to this?
    Also where should the perlite/vermiculite layer go? Above or below the concrete slab. A lot of differing opinions here!
    Thanks in advance.
  • Neil2
    • Oct 2006
    • 1374
    Re: Concrete for the hearth slab.
    Do you mean the "suspended slab" ? This is the reinforced structural slab on top of your wall which supports the insulation layer, then the hearth layer.
    This is normal portland cement concrete. If mixing your own - go with a 1:5 (portland/aggregate) mix.
    Normal Portland based concrete starts to give up its internal bonding if heated past and then back thought 650 Fahrenheit or so.
    You need some insulating layer between the suspended slab and the hearth bricks. This layer is usually a 1:5 or 1:6 portland/ vermiculite mix about 4 inches deep. Some use a thinner layer of vermiculete and add some other type of insulating material.
    • shuboyje
      • May 2009
      • 406
      The best answer I can give you is download the free ebook from the store and read it. IT will answer these questions and most others you will have. It's a great text with lots of pictures.
        There are no differing opinions on this issue. It's fully settled, that having to heat up your entire support slab to oven temperatures, insulation underneath or not, means you'll be burning entire forests to get your oven up to bread baking temps, and you'll find it difficult at best to achieve pizza temperatures.
        Insulate! Insulate! Insulate!
          • Jul 2009
          • 19
          Thanks lads I appreciate your input. Just the answers I was looking for but with so much information on the web showing the insulation going on below the slab and also stating that heating up the suspended slab takes no time at all goes against all common sense. I thought I was missing something.
          I have seen aggregate explode at relatively low temperatures and could not understand how some builders are laying their fire bricks directly on the concrete slab with no insulation.
          Thank you all once again. I’ll download the book.
          • Ken524
            • May 2007
            • 1655
            Those builders are the ones that come here and ask "Why isn't my oven working?"
            Thank you all once again. I?ll download the book.
            Here's the link to Forno Bravo's Pompeii page and eBook download:
            Brick Oven Plans | Build an Italian Brick Oven
            Be sure to keep us up to date with your project!
            Ken H. - Kentucky
            42" Pompeii
              • Jul 2009
              • 19
              I downloaded the plans and I should have done it sooner. They answer all my questions. Excellent stuff.
              I'm building a big bugger and am finnishing the shuttering for the concrete pour next week. Here's a pic. Stand measures 10'x8'.
