Mr Gs Aussie Castable oven.
  • sonomacast
    • Jul 2006
    • 150
    #31
    Re: Mr Gs Aussie Castable oven.
    Great oven MrG,how did you keep the separating forms in place when you concreted and vibrated the cast? Thank you
    • mr g
      • Jan 2008
      • 66
      #32
      Hi Jason, I used a bead of silocone on either side of the forms to attach them to the mould. After a few ovens the silicone worked it's way loose. Instead of re-applying the silicone I just made sure to evenly apply the concrete on both sides of the mould so that there was equal concrete on both sides which helped to keep the forms in place. This worked pretty well too so either way should be ok for you.
      John.
      • heliman
        • Sep 2009
        • 1181
        #33
        Fascinating project - well done!!
        / Rossco
        • Mitchamus
          • Aug 2008
          • 389
          #34
          great Job!
          Which castable did you use?
          cheers,
          Mitch.
          My 2nd Build:
          Is here
          • mr g
            • Jan 2008
            • 66
            #35
            Vesuvius, which has the same specs as Silacast 145.
            • Jayson
              • Nov 2010
              • 27
              #36
              Hi Mr G,
              I love you aluminium oven door. I live in Melbourne and am part way through an oven build. Where did you have the door cast. I assume a local foundry did it for you?
              Jayson,
              My Picasa Web Photo Albumn - https://picasaweb.google.com/1140387...eat=directlink
              • mr g
                • Jan 2008
                • 66
                #37
                Yep, local foundry in Kilsythe
                • robertjusher
                  • Sep 2009
                  • 89
                  #38
                  HI MR G
                  I am looking at the same idea for mine.
                  I have broken ground and hope to get the boxing done next weekend so am a little way off !!
                  I am going to do the cast dome (today's plan) as I am no bricklayer and don't want to cut bricks. I was thinking of 1 piece mound in place (sand mould)with SS needles to help hold together in case of any cracks. Any thoughts on a 1 piece mould, or is more going to be easier in the long run?
                  More questions...
                  How much did each 25kg bag of refractory cost?
                  How's the oven and the other 9 you made going.
                  Any thing you would change?
                  Rob
                  • mr g
                    • Jan 2008
                    • 66
                    #39
                    Hi Rob, I think a one piece oven will be fine. I went with pieces because we weren't making them in the place where they'd remain (due to the number of ovens).
                    The bags were approx $35 each at the time but that was a big order so there was some discount available and it was 2 years ago.
                    The ovens are all performing beautifully with no problems. I'd give them a 95/100.
                    I would change a couple of things:
                    I would make the flue opening bigger - that is 8inches instead of 6inches. I expect that would help to minimise the smoke at firing up time. I stress that 6 inches is not a problem but 8 inches might just make it draw a little better when firing up.
                    I would also make the entrance a couple of inches lower to encourage the smoke up the chimney rather than out the front. This is only an issue at fire up time when it's smoky.
                    I would not change the door opening however. That is a perfect size.
                    I would also consider stainless steel needles around the entrance where the chimney gets quite hot. I have had some hairline cracks appear but it's no big deal. Other than those things the rest of the design is fine.
                    Mr G
                    • Johnny the oven man
                      • Jun 2008
                      • 399
                      #40
                      Refractory prices are still about the same, we sell Vesuvius 135 for $30/20kg bag, your right about 8" flues, the 6" is just that little bit small. Stainless steel "needles" should be added to make the cracking minimal, best to use it in the whole dome if possible.
                      • TapRackFire
                        • Jan 2012
                        • 36
                        #41
                        Great build Mr. G,
                        I am torn on how to do my dome. If I built one like yours, do I need to add rebar to it? Would that not make it stronger? I have thought of using a steel dome from a propane tank and covering it with refactory concrete, but having trouble finding a dome large enough.
                          You could try rebar, but the recommended reinforcing is stainless steel needles, presumably for a reason. Better to stick with what's recommended IMO. Mild steel will be prone to rusting in time. High temp will accelerate any reaction and rusted steel expands in volume creating stress points and fractures.
                            The purpose of the fine fibres in the castable mix is not to provide strength because they melt at 160 C and then burn away leaving a network of tiny pipes that can safely eliminate steam.Some manufacturers use natural fibres that just burn away, others use polypropylene fibres that melt then burn. These are different to the stainless steel fibres that are added to provide extra strength.
                            • Aussie Pete
                              • Jan 2012
                              • 160
                              #44
                              great ovens Mr. G, surely your not a novice at this, you've done a fine job.
                              I have a quick question, i am doing a castable dome also (over sand), i think i might add some stainless needles in my mix, does anyone know where to get around brisbane, or what kind of supplier to go through. is there a thread on here somewhere, that goes into more detail about them, (such as size of the needles & quantity in the mix).
                              Mr. G, do you have pics of how you transitioned your thermometer into your dome.
                              Aussie Pete
                              250th Aussie on this forum...."so i was told"
                                add 2% by weight. Try Antec Engineering.FIBR446/25-C
