I hope I'm posting this in the right place. I'm really new at this.
First I want to thank all the contributors to this forum for the great information, it provided the guidance and inspiration I needed to get this far in my project. Also, many thanks to the folks that provided supplier information in Florida.
I have completed the dome and I'm at the point of insulating it, my question is - will the Vermiculite/cement mixture on top of Insulation blanket (Superwool) and chicken wire compress the insulation and reduce the insulating properties.
I'm considering the following and would like your comments:
> Should I use a layer of aluminum foil between insulation and vermicrete?
> Instead of chick wire should I use stucco lath which will provide more holding/binding for the vermicrete and not compress blanket much.
