Or is it immpractical or too messy?
Can you build and archway without cutting the bricks?
Re: Can you build and archway without cutting the bricks?
http://www.fornobravo.com/graphics/P...e/6thchain.jpg
Building the Oven Opening
There are four traditional ways for framing your door opening, though we recommend the first, and easiest method. The easiest, fastest and least costly way of framing the oven opening is to use standard size bricks to frame the side of the opening, and a length of 2"x 2" x 3/16" angle iron to support the top of the opening.
You can build an entire oven without cutting bricks.
I concur with dmun, the Pompeii plans are extremely simple, virtually no cutting at all (well I guess the bricks are all cut in two).
Yes, you can build an archway without cutting the bricks. My house has multiple archways that are made using uncut rectangular bricks. That being said, my house was built by a very skilled mason who had done it many times before (not me). Now the question is can you make an arch without cutting the bricks. I've only made one arch to date and haven't taken the form down yet, so I can't tell you anything but yes it is possible. The first picture is the arch made by a professional, the second with form still in place is mine.
Good luck,
Eric2 Photos
Originally posted by eprante View Postthe second with form still in place is mine.
Eric
Most older traditional arches used non cut bricks, or rough arches as the are called.
