Modular hearth for Casa2G
  • rdelmendo
    • Mar 2010
    • 6
    Hi all-
    First post, about to embark on first WFO with a Casa2G that I plan to install with an igloo mosaic finish on a metal stand. My plan is to weld 2" L angle as the frame with 1" L angle as the cross members and rebar on top of that going the other direction. Then pour a 4" hearth on top of this frame. The hearth could in theory then be placed on a welded metal stand.
    So the questions to the experts on the forum:
    - Is 4" enough for the hearth?
    - Any guess on how heavy this will be? Should I pour the hearth with the frame on the stand already?
    - Should/could it be vermicrete?
    - Is the FB kit board fine to put directly on this hearth or should I add a second layer of something else?
    Thanks in advance for the advice. I'll post pics as the project develops.
    Cheers,
    Ron
    Re: Modular hearth for Casa2G
    Yes.
    Normal weight concrete -- a mixture or sand, cement, and stone gravel -- has an accepted density of 145 pounds per cubic foot. Divide by three for a four inch slab per square foot.
    Yes. Lifting that big a slab is an unneeded and potentially hazardous rigging job.
    No. Vermiculite or perlite concrete has no tensile strength.
    If your slab if flat, nothing else is needed. If not, a mixture of fireclay and sand can be used to level it. I placed my insblock19 boards in wet concrete with good results.
    • james
      Brick Oven Merchant
      • Mar 2005
      • 4648
      Hey Ron,
      If you pour a traditional concrete hearth, and screed it reasonably well, you will be able to lay the FB Board directly on the concrete without anything to level it.
      Think of it this way -- the concrete is 100% structural (it holds everything in place) and it does not provide insulation value. The FB Board is 100% insulation (it does a great job of blocking heat in the oven) and it does not provide any structural value.
      It's easy!
      • christianb
        • May 2010
        • 1
        Do you even need a concrete hearth? Why not just use a piece of plate steel.
        • fxpose
          • Jul 2009
          • 942
          I originally liked the idea of using a steel plate for my build. What immediately turned me off on the idea were the cost of the plate stock and the additional cost of having it cut to a custom shape/size.
          The concrete hearth I poured cost me at least 75% less.
          George
          George
          My 34" WFO build
