The freight company will be dropping the oven kit off on Monday and I am gearing up to do assembly. My base (pictured) was finished last week.
I understand that water is an enemy until the final coat of stucco goes on, so should I'm planning on tarping if rain interrupts the build. I've read through the instructions several times and I think I've got the assembly down. I'm planning to finish it as a gray igloo.
I'm new to stucco, so is there a primer online worth reading? Products worth recommending? I hear there is a partial vinyl stucco that I should use as the final coat. How long should I wait between coats, how many coats, etc? Any and all stucco advice is appreciated!
