I used super isol board for my hearth insulation and now that my dome is in place I realize that the expansion space between the floor and dome is pretty generous - 1/2 to 3/4 inch all around. The instructions are crystal clear with regard to the fact that this space should not be mortared so that things can move as they heat and cool.
I'm a little concerned about water. I won't have much of a roof overhang and my entry arch only protrudes about 4 1/2 inches in front of the Casa shell. I don't see any indication that the board will be damaged by small amounts of water, but it sure will absorb a lot - it sucks water right out of mortar.
Any suggestions on waterproofing or whatever without compromising the expansion gap? With the door provided, rain could still get between the landing portion of the floor and the dome entryway. Any water that gets in there will need to be evaporated off one way or the other. It just seems like it would be better to have it trapped in the oven chamber than leaking into the insulated space.
