Broken FB Insulation Board
  • d0rifto
    • Feb 2010
    • 18
    Hello!
    I picked up my Casa 2g 90 last Friday and drove back home to so cal.
    I had the help of a friend to take the oven out of the back of the truck.The oven dome was quite heavy when removing it from the base. We ended up damaging the insulation board. It seemed quite fragile.
    Does look salvageable?
    The problem I see is not the landing area where the floor tiles go, but rather on the side of the insulation board. This is where the dome sits on.
    What do you guys think?
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    Re: Broken FB Insulation Board
    Hey d0rifto,
    I know that we have been in touch with you via email, and wanted to confirm what we said. Try dry assembling the oven dome and floor on the insulating boards, and if the oven is stable, you should be OK.
    If not, just let us know and we will replace the damaged board at no charge.
    Once the oven is assembled, the board insulation does not get much attention. It just sits there insulating the floor of the oven. :-)
    • d0rifto
      • Feb 2010
      • 18
      Hello James,
      thanks for the quick reply back!
      I will let you know how the build goes and if I need the replacement board.
      Davis
