How hot or warm can I expect the bottom of the oven when there is 2" of FB board. Enough to burn something or someone that happens to put there hand under it? Reason I'm asking is because I'm building a wood platform that will
Have a layer of 1/2" non combustible glass roc board covering 1/2" plywood and 2x4 cross pieces. Would the heat be enough to burn the wood?
