Re: This oven is so funny.
Bad ideas never die. That's one of those south american hornos. When I was looking they were being imported from Uruguay, of all places. Who knows, if you plugged the hole, built a real vent, and swaddled it in insulation, you might even have a working oven.
Originally posted by david s View PostIs that a flue pipe or a sleeve for a thermocouple?
Interesting. It creates problems with the inner dome creating pressure on the outer dome as it expands. I tried putting one in at floor level on my second oven. It has the advantage of being able to fire with the front door in place. Don't really understand why it's so high up, is it an intake or an extra exhaust? Looks too small for either to me, but if lots of them use this system, presumably it works.Kindled with zeal and fired with passion.
I would presume that it is an exhaust that allows a draw of air through the oven during firing. The subject was brought up by Dan Wing at a wood fired baking class I attended. He didn't elaborate much on the topic other to note that it was difficult to get a fire going in these ovens if the vent was not present.
we have someone selling ovens here in the uk on ebay where the chimney comes out of the top of the dome. the sad thing is he has sold many.
KL Wood Fired / Burning Outdoor Pizza Oven Superior kit | eBay
Don't put them down too much. I tried a central flue for my first oven and it worked really well. The main disadvantage is that quite a lot of heat is lost up the flue during fire up, which means they would use more fuel than an equivalent sized cross draft oven. But they also have the advantage of no front flue to work past which also saves space and they're simpler to build, plus no smoke at start up and they draw really well. But you do need a damper or cap on the flue to lock in that heat for roasting or baking.Kindled with zeal and fired with passion.
Originally posted by sonomacast View Postwe have someone selling ovens here in the uk on ebay where the chimney comes out of the top of the dome. the sad thing is he has sold many.
KL Wood Fired / Burning Outdoor Pizza Oven Superior kit | eBayas the flue is outside the oven.
