I'm just starting project for modular pizza oven. Have laid 8" thick reinforced foundation onto which I'll build concrete block base. My questions are to do with materials for hearth. I have concept of using concrete lintels 100mm X 65mm (4" X 2.5") laid between the concrete blocks then topped with 12.5mm Hardibacker board, then either making insulating layer of vericrete & CALSIL board or just CALSIL board without Vermicrete. I figure maybe I'll need 4 lintels to bridge the 1.2M square gap adequately. Does anyone have any experience of doing this rather than pouring concrete hearth? Are there any risks or potential poor performance with oven? Cooking surface will be firebricks.
Also thinking if I can use 140mm wide hollow dense concrete blocks rather than normal 215mm wide as they should be lighter to handle, with every other hollow filled with concrete - is this likely to be stable enough?
Thanks in advance for advice - don't want to screw up through trying something new.....
