Shaping vermiculite concrete dome
    Re: Shaping vermiculite concrete dome
    Originally posted by Les
    Gulf,
    I wished I would have thought of that. I did mine with rebar and wire and it was a bitch. Yours is incredibly symetrical...
    Thanks Les,
    In all of my experince with building (born as an endentured servant into a construction family ), I have been taught to rely on measurements, levels, strings, speed poles, templates (the list goes on). I did not trust my "young eyes" so I definately don't trust this old pair that I have now .
    Originally posted by Neil2
    The chicken wire seems to be to hold the blanket in place. If you are using vermacrete as insulation for the dome you can skip the chicken wire.
    I probably, could have saved that step (and $) for the render . I am planning to install a layer of stucco wire in the render over the vcrete. I will be laying 1/2 concrete splits over this to finish.
  • Les
    Neil,
    I used the wire over the rebar to form the dome. I slopped vermiculite / portland in between the wire and the blanket.
  • Neil2
    The chicken wire seems to be to hold the blanket in place. If you are using vermacrete alone as insulation for the dome you can skip the chicken wire.
  • Les
    Gulf,
    Most just shape the vcrete by eye and do great work. Some have used templates. I can't swear that it is easier to use a template but here are some pics of mine.
  • clg763
    started a topic Shaping vermiculite concrete dome
    I would like to hear some ideas for the easiest way to shape a vermiculite concrete dome over my modular oven. I have blanket insulation and want to finish it with a stucco dome, from my reading, the simplest way to do this would be to shape vermiculite concrete over the top. I have seen several different people make rebar armatures for their oven and place the concrete on the that, I have also heard that all you need is the vermiculite concrete to shape the dome. I am worried about maintaining a decent looking dome shape with this approach.
    I know many have done concrete vermiculite domes but I am having trouble finding good builds and photos from my searching.
