It will be a while before I'm able to start the actual oven build but patio work is finally started. This is a picture of the pad where the pizza oven will set along with a fireplace- oven on the left, fireplace in the middle, then a small wall on the right that will be a bit of counter space. Floor will be stone pavers and the area will be covered by a 14'x18' pavilion with a metal roof.
My kit was delivered a few weeks back and the contractor will start the stand for the oven and fp next week, we'll give the concrete for the pad time to cure through the weekend. We're having some light rain and cool temperatures so should be good conditions for the concrete to set up.
I plan to at least set the oven on the pad temporarily during the pavilion construction so we can set the hole for the chimney to go through the roof in the best spot. Would be nice to start the build but don't want to be in the way. Stand will be a bit over sized so we have some leeway in order to make sure we miss a rafter, etc.
Should be fun and will try to post pictures as we move along, will probably just be some patio updates for a while.
