I recently purchased a Professionale 120 TE(trailer Edition) oven from FB. I will be building and attaching this oven to a mobile trailer which will be built by a local trailer manufacturer. I've been a member of the boards now for close to 3 years with limited posts. My journey started here wanting to build an oven in my backyard and ended up with me adding an oven to a trailer for catering purposes which is what I do in my day job.
There is a ton of great information on here & I hope to be able to share my experiences on the board while building this oven. I am assembling different trades to help with certain aspects (stucco, stainless steel work) in order to make the trailer as professional as possible. I have limited building experience & hope that some forum members will be able to provide guidance & ideas if needed.
My first few hurdles involve the directions for building the oven:
"Lay insulating boards on hearth & spread a thin layer of sand on top of boards."
Okay, first question is how thick should my hearth be considering that I need to keep the weight down because it is going on a trailer?
I also realize that I am going to need to build a tray to build the oven in which will eventually be attached/welded to the trailer. More questions on this to follow.
Second question is what type of sand should I be spreading and how thin is thin?
