I am beginning installation. I have already poured the foundation but have been second guessing the size of the foundation. I plan to use wall block for the stand and oven surround. Looking at the recommended size of the hearth from FB, i should be good. However, i would like to make any changes now. The current size of the foundation is 54 x 61. I plan to make the stand 54 x 60.
I will initially stucco the dome and then surround it with the block as I have time.
What does everyone Fill the empty space with? Or should I leave the air space?
How do I keep water from entering the space between the oven and the surround when using the wall block
For the enclosure?
Thanks for your help in advance.
For the enclosure?
