Edit: just realized I posted to wrong forum (not meant to be in Brick Oven forum). I'll see if a mod can get it moved)
Here's some photos of my build from Morgan Hill, CA. My dad's done a few ovens (1 at home and 2 at work), so his housewarming present was the oven and coming over with some guys to help build it over a few weekends. Pictures kind of show it all, but here's the overview:
- Casa 2G100 oven
- Base stand was laid on existing brick, and we used mortar between the brick and cinder block to get it level.
- Since we were cutting into the hill, the stand just came out 32" from the existing retaining wall.
- After cutting out the wall section and hillside, we broke up the removed retaining wall chunks and laid them into the hole dug into the hill. The dirt was dug out 4 inches or so below the level of the retaining wall cutout.
- The slab on top was 3.5" thick over the stand, and about 6-8" thick (on top of the broken up wall pieces) in the hillside.
- Framed and poured more concrete around the front of oven as a base for the granite counter. Height of the slab was set so the granite counter would be level with the floor of the oven.
- Note on the granite bull nose: it's only rounded on the top and then has a vertical front. We learned from my dad's first oven that if you do a traditional rounded bull nose, water will run around and get into the drawers. by having a vertical face, the water runs off a few inches in front of the drawers.
- Not shown in the last picture, we did stucco the front and inside of the base stand. The mini-pillars on either side of the oven (part of the rear retaining wall) were faced in granite similar to the front of the oven. We'll eventually run electricity there and mount some nice wrought iron lights.
