Hi All,
Got a quick question regarding mortaring joints between precast refractory panels...
The kit I have comes as 4 pieces for the base and 4 pieces for the dome. Instructions call for assembly then give a 30mm coat of cement around the outside perimeter of the dome.... but they also don't have any fibre board insulation underneath the base which I've added thanks to these forums..
Basically there are a few largeish gaps inside the oven, specifically around the perimeter of the base where you can see the ceramic board underneath. Should I mortar around with high temp mortar (have some wet mix vesilux 3000 available)? I'm basically concerned about any nasty chemicals that might come from the ceramic board (nice and itchy after cutting it so it has me worried about what it will do to the food thats cooking inside!).
Or am I basically trying to solve a problem by mortaring with another chemical thats probably just as bad as the board?
Silly question I know, but better to ask!
ll of a gap), I would place a band of corrugated cardboard against the base of the dome walls. It can then be left to later burn out and fill in with ash. I think that I would also leave some expansion joints in the grout about every 8? to 1? around the perimeter of the floor. Again, I would use the cardboard at each joint. That would break that long ring of grout into smaller sections.
