Insulated Hearth
  • Howie
    • Apr 2005
    • 23
    Insulated Hearth
    I'm getting ready to pour the insulated hearth for the Premio 120 Modular Oven. This is turning into a real scavenger hunt. I notice that the insulated hearth is poured using Calcium Aluminate Cenent to create refractoty concrete. Altrnatively regular concrete. Will the regular concrete hold up? Or should I go the distance and use the Refractory Concrete?
    TIA
    Howie
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    Hi Howie,
    I think you really only need Calcium Aluminate concrete in a commercial oven that is fired 24-hours a day. A large percentage of home ovens are installed using standard concrete (in fact there are installation guides from producers that recommend a simple, standard concrete hearth without any insulation). If you have an easy, local source and it isn't expensive, you could go for the calcium aluminate, as it will last longer (probably long after we are all gone) and perhaps heat up a little faster, but the difference is not worth a lot of effort.
    • aikitarik
      • 107
      Would this be true for the Pompeii as well? I do have an inexpensive and easy source of this concrete (and mortar) and was already planning on purchasing it for the oven build.
      It never occurred to me to use it in pouring the hearth. I'm planning on trying to do the island hearth, BTW, which seems slightly challenging since I have to pour the island while the perlite insulative layer is still wet, which means removing the island forms. Time will be important.
      Tarik
      Tarik
      • paulages
        • May 2005
        • 297
        if you are already pouring an adequate support layer as described in the other thread about the island hearth, i believe you could just make a circular form out of sheet metal to separate the thermal concrete from the surrounding perlite layer, and just leave the metal form in the concrete. i would set in a half inch or so beneath the surface.
        -Paul
        My 2005 pompeii build
        • aikitarik
          • 107
          Logical... dunno why I didn't think of it! :-)
          I was not planning on pouring an extra support layer.
          The back 2/3's of the oven hearth will be supported by sitting on a 6+ inch poured concrete foundation poured behind a 3 foot high, 6-7 inch thick concrete retaining wall.
          Only the front 32 inches will be supported by concrete blocks as in the normal design. I am reasonably confident that I don't need the concrete layer under the insulation layer for this as this would only be supporting the throat of the oven.
          Let me know if you think otherwise.
          Tarik
          Tarik
          • ColonelCorn76
            • Mar 2005
            • 97
            How do you think I feel?
