I'm not really a wood guy so I think of solutions in terms of masonry first but now that you mentioned it I don't see any reason why you could not cut sheets of OSB the dimensions of the side support walls and glue them to the block inside. This would be very easy and a relatively inexpensive way to solidify these walls. Doing this would eliminate the need for the curbing.
I suppose you could do a version of this on the outside of the back wall. Cutting a piece large enough to cover the entire back of the base. This would join the 3 walls (2 side walls (6 or 8") and center wall in-between them) You couldn't do it inside because what we are trying to do here is tie the sides and the back walls together to create a solid U shape.
Now this is assuming the back wall fits "in-between" the 2 side walls like the attachment below. If the back wall is on the "outside" of the sidewalls this will not do any good.
If this back wall is tied into the side walls either with rebar or alternating block you do NOT need to worry about the back.
Your bad news is actually good news
As to the 4 x 4, again I'm not a wood guy but I don't think this would be the cause. Even if your getting the heath slab hot to the touch (above say 120 deg) its going to expand in all direction and if anything place a downward load on the 4 x 4. I cannot speak as to the expansion properties of wood itself.
I think what you have is the slab expanded during use (normal) Since these center "wall sections" are tied into the slab via the rebar, also normal,(to be tied in not the sections) when it expanded it pulled a bit on these joints, it doesn't take much to create a crack along a continuous vertical joint. If it has separated thats a different story. Then again if the "new half" of the slab on grade was not compacted properly the back section could be moving slightly. Does the old and new meet below this crack? you say the slab has no cracks did you look at it under the oven where the old and new meet? Or it just could be a crack because of the blocks being stacked like they are. My gut is telling me its from the slab after all the wall has not cracked along the other vertical joints and the rebar is in the block that have the crack.
So at this point it looks like your concerns are sheering up the back wall if it looks like the attachment and keeping an eye on that crack in the hearth slab. There is no point doing anything about the hearth slab right now. Wait and see if it gets worse after a few more firings.
Please keep in mind my concerns with stabilizing the base are strictly for insurance in the event of an earthquake. The oven will probably never move, surely not on its own but if it were to move in an earthquake even a decent tremor it has no side to side strength. Based on what you described retro fitting the base would mean a difference (in a quake) between serious damage/ possible collapse and some minor repair.
