Re: Oven support wall cracking
Ok I am not an expert am basically a newbie but I am a bit of a lateral thinker so I will put my 2 cents in. Once you have added extra footings support under your slab why not lay anoter layer of concrete blocks in a stretcher bond pattern and tie these into the outside wall with bolts/ rebar or something similar. You wont be able to do the internal wall all the way to the slab height but if you tie the 2 walls together wouldnt the internal wall act as support for the external wall ?
Just a thought but as I sai I am just a newbie.
Imran
Originally posted by Unofornaio
View Post
Imran
