2G90 / wet polished concrete counter and brick in Temecula
  • Pizza Bear
    • Aug 2016
    • 32
    #16
    Sorry guys for not replying
    some what new to the forum and I have been really busy with work
    easier than you think to do this type of counter top especially outside where water from a wet polisher is not an issue
    it really is like pouring a reinforced concrete side walk on top of a block wall
    I supported it with hardy backer
    poured with a 2500 psi standard mix no need to use fancy counter top mixes or light weight blends
    I use Davis concrete colors this one was a really inexpensive color (black colors are cheaper for some reason)
    the biggest investment is a wet polisher $200-$300
    for the best adhesion with a lacquer based sealer you only need to wet polish up 200 grit
    I started with 50 grit, then 100 then 200
    it took all day in a rain suit, rubber boots, and I had my I phone earplugs in under by ear protection
    best to listen to Led Zepplin, or the Pink Floyd station on pandora for this kind of work
    thx Rob
