Hi,
I'm a newbie to the forum and midway through installation of a Valoriani 110 cm modular. I didn't get it from CA so don't have access to their forum...I have not been able to find ref-mix locally and shipping costs being what they are, I've been looking for an equivalent to add an inch to the dome for greater thermal mass. I plan to do some extended cooking...I found Moldit-D locally and the specs for elemental content are very close to ref-mix. Does anyone have experience with this material? OK to cover the dome with it?
A different question on vents for the loose fill chamber...I plan to use perlite and cover the upper chamber with flat stone/mortar covering. The instructions that came with the oven state (in large letters) that openings must be left for transpiration. Design layout and installation photos on the CA site show no provision for this so I e-mailed Italy and the response was that the openings are definitely required-presumably to vent water vapor. I plan to use a minimum of small 1/4" holes (maybe 5-8 of them) for this purpose. Is there a discussion on this anywhere? What do most FB builders do?
Thanks!
Thanks!
