Looking forward to following the progress of your build!
. It is actually easier than any that I have built for an install. It is made from a 3/4" to 1/2" pvc bushing, a 3/4" electrical conduit locknut, and 1/2" hardware cloth. The galvanized mesh can easily be shaped to fit the dome within a layer ofr stucco. (I would spread some pvc glue on the fitting as the locknut was tightened) The idea is to secure the fitting into the stucco in a way that it will not turn while installing or removing the vent or plug.
. This is a situation that a vent (breather cap) built into the insulation/stucco interface really helps reduce/eliminate cracking from steam expansion.
