fire brick hearth
  • wrs
    • Jul 2008
    • 5
    fire brick hearth
    I have some bricks that are uneven on the hearth and was wondering if anyone knew what the best way to level/plane those down . That being said after reading this forum every night until my wife takes the mac out of my sleeping lap I feel certain that many of you know the remedy. I await your response and appreciate each of you.
    Wayne in Austin Texas
  • Les
    • Sep 2005
    • 2945
    Re: fire brick hearth
    Use a belt sander - I bought the cheap belts at Lowes.
    Les...
    • wrs
      • Jul 2008
      • 5
      thanks would a grinder with diamond cup work as well?
      • Les
        • Sep 2005
        • 2945
        I guess that depends on the skill level - I found that my grinder tends to go where it wants. The sander is easier for me to control.
        Les...
        • Dutchoven
          • Apr 2007
          • 931
          wrs
          Also depends on the size of the cup...small one will be very easy to dig in to the bricks...larger one would be easier to handle...but I would follow Les' recommendation...look at that beauty of an oven he built!!!
          Best
          Dutch
            Try a masonary grinding disc for your angle grinder rather than a diamond cutting blade, it shouldn't dig in so much and you should be able to operate it at a flatter angle.
            • Wiley
              • Mar 2008
              • 804
              Some people are more at home with a belt sander but for myself I prefer a "square face" on a sander/polisher. Unlike a round disc it's just about impossible to cut a "smile" using it and you end up with a really flat surface. Sand paper by the sheet is much cheaper than by the belt too with a larger selection of grits.
              Wiley
              • wrs
                • Jul 2008
                • 5
                Thanks again to all of you . This is an amazing site and knowing that this much experience is around made it so much easier to jump off the ledge and start this project. I am not sure how you have time to post pictures as you go but I will catch up in that area soon.
                  Also, remember the factory surface of the firebrick is harder than the interior: I recommend only abrading the edges that actually are catching the peel, instead of trying to sand the whole floor.
                  • christo
                    • Feb 2006
                    • 913
                    I have a few bricks that are prouder than others.
                    Never got around to sanding them down. - with the herringbone pattern, I don't seem to have any issues with the peel catching any...
                    To me - I'd go with it and see if it becomes a problem before I'd fix it.
                    Christo
                    My oven progress -
                    sigpic
