Cracked cooking floor when uncrating
  • sakoman
    • Oct 2008
    • 26
    While uncrating my new Casa 110 I cracked one of the 4 cooking floor pieces
    It is a 6 x 6 inch triangular wedge from the center of the oven floor.
    Can I just dry fit this piece and continue with construction? Or should I order a new floor piece?
  • Dutchoven
    • Apr 2007
    • 931
    Re: Cracked cooking floor when uncrating
    I would suggest contacting either James via private message or just go ahead and call someone in the service department at FB...they have a lot of technical experience and should be able to give you the best advice!
    Best
    Dutch
    • sakoman
      • Oct 2008
      • 26
      I ended up calling FB for advice. They suggested that I proceed with the installation and fit the broken pieces together with a small amount of refmix. I did so and it looks fine.
      They were very helpful and reassuring. They also offered to provide me with a replacement floor segment at their cost.
      They said it isn't unusual for the floor to develop cracks after installation due to thermal stresses, so I chose to just go ahead and use what I have. I guess I am just starting out with a "pre-aged" floor
      • Dutchoven
        • Apr 2007
        • 931
        Good for you! I am happy to hear that! Good luck with the rest of the build and we are here to help!
        Best
        Dutch
