Fiberglass Insulation?
  • Craig B
    • Jan 2008
    • 4
    After putting the blanket insulation around my dome, can you use fiberglass insulation?
    TIA
    Craig
    Re: Fiberglass Insulation?
    Domestic fiberglass insulation is not recommended. It has a glue like binder that gives off nasty smells at higher than domestic temperatures.
    • exipnos
      • Aug 2008
      • 43
      While regular fiberglass insulation have a low temperature point that might not be suitable for your wfo, you can easily source the rock wool kind of insulation. This is at a similar price point but is very suitable for the oven installation. Especially if you already have blanket insulation.
      Cheers,
      Kosta
