I guess for the straps I'm more concerned about how the corners are fastened, and the straps are so easy in that regard. I don't think the straps do much to prevent bowing (they might even worsen it if your wood has a lot of bow, think violin string) but if you have a 2x6 or 2x8 that has some twist to it you can drive it square with the straps (I used 2 to bring both top and bottom corners into alignment). You certainly can use the straps later when you pick up materials for the finishing of the project with your neighbor's old pickup
. However, conventional concrete form nails are cheaper and should hold.
