My plan has been to install a slab of perlcrete as the pad over which to build a pizza oven. The general method was to pour the perlcrete into a wooden form set on top of the firebricks off the ground. The bricks would have an old shower curtain over them to keep the cement from getting on to them. My assumption was after some cure time, I could remove the form, pull out a few bricks, get some hands under the thing, lift it up, and rest it down on top of my cinder block base with some mortar ready to go. I have not had much luck with this.
In the first attempt I had used concrete instead of cement. After two weeks, I had something that crumbled apart right as I tried to pick it up. It would break off right at the corners. That's when I realized I should have been using cement. So I have tried again with a 1:6 ratio of Type I Portland cement to perlite. The slab is poured about 4.5" thick; that's about how much I had yielded when all was done. The pad is a square four feet to a side. There is also two meshes of rebar inside.
The past few days, the weather got down to freezing overnight and there was some rain in the forecast. I had covered it over in a tarp for that whole time. I think it had gone roughly 24 hours w/o a tarp when the weather was still okay, then it got covered the night things were supposed to get bad. I think this will be the last freezing night. I checked the tarp and noticed a lot of condensation on it that I removed.
What has me a little afraid is I found a small chunk not level with the risk that I managed to break off. I found I could bust that little piece in half just about the same way I could with the perlite and concrete, so I'm afraid I screwed this up again.
I am wondering if this method is even possible, or if I should be doing something else to prepare the base for my oven. I can get more materials tomorrow before noon when the place here closes, and I'd want to use the weekend to get this right. Or if you guys think it needs to just cure some more in warmer weather, then I'll leave it alone.
Given I already blew my first slab, I want to get this working right ASAP. I've had my firebricks and clay for awhile now just waiting to be used.
erlite, the edges broke right off when I lifted them up, but the core of it was pretty strong. I had to break the center up by lifting it up and dropping it down onto my patio slab. This new pad is 1:6 cement
