Re: Preparing for steel oven build.
Scarnucci
Where I come from Quikcrete is a mix that when water is added makes concrete. It has gravel and sand and cement.
You do not have to use refractory (calcium aluminate) cement when mixing vermicrete, regular portland type 2 will work just fine. Probably portland type one or even "plastic" cement (which is plastic only in consistancy/flexibility not made of plastic) would probably work as well. There are a couple of good threads concerning how to mix so I would advise checking the archives. RTflorida (if memory serves) had a procedure for mixing and placing which allowed for high insulation with little cement and lots of vermicrete (9 or 10 to 1 vermicrete to cement ratios are possible). The threads are a couple or three years ago.
Hope this helps,
Wiley
Scarnucci
Hope this helps,
Wiley
