I have picked up my Foamglas 2.5 inch insulation. I found it to be a bit more fragile than I anticipated, so I am planning to place 2 inch thick cal-sil board over it and the bricks of the hearth on top.
Would it be wise to use some kind of fireproof insulating tape or cement between the concrete slab, Foamglas, calsilboard layers?
Will the weight of the oven and the housing be sufficient to keep everything in place?
Thanks, Sarah
Thanks, Sarah
