I'm going to be building my hearth tomorrow and have a few questions. Keep in mind that I am planning a community bread oven.
There is growing interest among members of my town in using the oven for bread and pizza. It is a small town and members are closely knit.
Therefore I am adding additional mass to my hearth by setting the bricks on edge. I plan on using thick insulation instead of cladding on my walls.
1) How should I think about securing the transition between the ceramic fiber blanket layers and the oven base? I have 5 .5 inches of insulation under the hearth (2.5 Foamglas, 3 calsil). I'm planning to cut the insulation boards close to the hearth as I've seen others do with their Pompeii ovens. How does one make sure that there is no heat escaping from underneath the blanket layers? Does the layer of vermicrete that goes over the blanket and chicken wire take care of that issue?
2) Next is a question about the ash drop- I have one that is 2 inches wide and 10 inches long. I'm thinking I might need at least 3 inches width, which I could cut before the hearth goes in. Would you recommend that I widen it?
3)Finally, due to my inexperience, I did not build my base after completing a final plan of the oven. I'm designing the oven as I go and I'm running into size limitations in width (I can manage a 36 inch hearth space) with my 5 ft 2 inch wide base. I'm thinking I could manage a 60 inch hearth depth (I have 8 ft 2 inches length). My original oven design was relatively square and more similar to the Pompeii style (I have Alan Scott plans for his 36 x 48).
I'd like to be able to cook with a fire in the back of the oven. A deeper hearth would allow that. Could I make the oven substantially deeper than wide and still have good airflow?
Thanks so much for your expert advice.
Sarah
Sarah
