Re: steel liner question
Thanks again Wiley,
I was able to get fine white silica sand. I followed your advice and did not add any perlite to the mix. I used the 50:50, fire clay:sand, blend to level the fire bricks and then cut out the form. I didn't end up bending the walls as there was enough space inside. The form felt pretty stiff so I didn't want to mess with it's integrity.
Here is what I have so far...
Any suggestions for that chimney hole on top?
BTW - "lovibond" is a brewing term as I am a brewer (answering the PM I received)
Thanks again Wiley,
. Covering with a layer of perlite/cement....not sure its required as most use it to cover the lumps and bumps left after trying to make the blanket fit over a dome shape. Being a barrel shape I dont think you will have that problem? I suppose theres onl;y one way to find out.
but of course I bias. I would consider covering the insulation blanket with a layer of render so you have something to mortar the brick too thats solid.
