I want to want to make a smaller oven, inspired by the comments from david s, somewhere between 55 and 60cm (21-24?) and have a couple of questions that someone with more experience may be able to provide. Most of the other issues I was having were answered in the forums already.
Have just picked up 150kg of a refractory material (Density 2.6 g/cm2 ; Thermal Conductivity 2.8 W/mK) which we use at work. As it?s trowelable material with higher density (about 20% more) and higher thermal conductivity (2x as much) than standard firebricks, this provides some opportunities and challenges when making the oven. It?s spec?d for 1000C / 1800F so temperature isn?t an issue.
Using a material with higher thermal conductivity and density ? does anyone have any experience with denser materials with higher thermal conductivity. Theoretically I can have twice the mass that will heat up in the same time as bricks. Or I could have the same mass of the bricks that heats up 2x as fast. If you had the option, which would you choose?
Different Dome and Wall Thickness ? would it make sense to make the top part of the dome thicker than the sides? Say 60mm for the top and 45-50mm further down on the sides? This would give more thermal mass on top?
Floor Material - Bricks vs Cast Refractory ? My gut feeling is that it is best to have the floor and the dome from the same material, particularly if they have different thermal conductivity, but is this really necessary. Would like to use firebrick in the floor but worry if the floor has a thermal conductivity of 1/2 of the dome then the pizza won?t cook evenly? Am I overthinking this?
Dome Shape ?I can trowel this material into any shape, so I am thinking of having slightly tapering walls with a completely flat dome with a height of 25-26cm with a small door opening of 40x16cm, similar to what I have read about David S?s oven. As I am not constrained structurally to a dome, then the flat roof could be a benefit over the dome as per some discussions I have seen here.
Ideas to try - anyone have anything they would have liked to try when making their oven but couldn't. One idea I am thinking about is making a small pocket/indentation on the right hand side of the wall to push some of the hot coals into in order to make more floor space available, yet be able to have some wood burning when I need it. I can even fabricate a small tray to put them into that would fit into the pocket.
Any feedback would be greatly appreciated.
Thanks.
Thanks.
