I wanted an oven without breaking the bank and I found the homebrew mix to be a tempting solution, but I was hesitating, because if it were to fail, I would lose quite a few $$$, time and effort.
I set out to experiment with the homebrew mix by creating a miniature oven to test the durability of the mix properties and its endurance thru multiple firings, cooking, etc.
I wanted to keep it simple and straight forward without much fuss. I mixed the 3.1.1.1 - added a good amount of fibers from a brown rope that was taking up space in my shed.
I went through the drying process with 3mil bags over the mix for a few days, then a few more days with a 100W bulb, then 500w ( the bulbs worked great, I have burn marks on my wrist to prove it)
After the bulbs I started with slow fires to finish the drying process ( after reading so many threads on the various steps of building an oven – I had not realized how tedious the drying process can be). You know the rest.....
The homebrew mix is a success. Onward to the Gigantic Barrel Forno, which will have steel needless and more brown rope added to the mix.
Below are a few pics on my Mini Forno in action. The Oven has a few stress fractures due to my impatience at the end mark (always the end) in drying it and possibly from moving it three times. ( It kept getting heavier with each move)
A special thanks to michelevit for his inspiration in creating a brickless oven on a shoestring budget. As for the way the economy is these days, every penny counts,
