Most suitable grog granularity
  • di11on
    • May 2014
    • 109
    Hi folks,
    I have found grog with two different granularities - 0/3mm and 4/8mm
    Given that I am going for a dome of around 8cm(3") thickness, which would be more suitable. Someone kindly suggested that I should shoot for an eighth of the total thickness which would point to the 4/8mm grade but is there a disadvantage or problem with going for finer than is required?
    My oven on a pallet build thread
  • Tscarborough
    • Oct 2009
    • 3341
    Re: Most suitable grog granularity
    Both, actually. What you want is a a range from dust to the largest size required. 0/3 means dust to 3mm, 4/8 means 4mm to 8mm, so a blend would work well.
    The idea of an concrete material is a thin matrix of cementious material surrounding graded aggregate. The aggregate is graded such that the interstitial spaces are as small as possible.
    • di11on
      • May 2014
      • 109
      Thanks TS... and if I had to choose one or the other (not that I will have to, but if I did?)
      • Tscarborough
        • Oct 2009
        • 3341
        The larger.
        • leetheldc
          • 255
          You really need 0 to 1 grade as fine as possible for a dome as the joint tamper from nothing to around 10 ml on outside of dome any granular larger than 3 ml and your brick would "rock" ie ground out on the gravel making for a nightmare to lay
          link to my effort http://www.fornobravo.com/forum/f8/7...art-20707.html
          "95% reading this forum 5% building"
          • leetheldc
            • 255
            Sorry not gravel but ground firebrick grog size
            • Tscarborough
              • Oct 2009
              • 3341
              He is not laying brick, he is making refractory concrete, the fines are already covered in the other aggregates he is using.
              • di11on
                • May 2014
                • 109
                And what about the sand? I've heard builder's sharp sand being mentioned. I'm not sure how I would identify that here in France - what distinguishes it? Can I use regular builder's sand? Is the granularity important?
                • Tscarborough
                  • Oct 2009
                  • 3341
                  Cleaned washed sand, it may be called concrete sand, torpedo sand, stucco sand, or sharp sand.
                  • di11on
                    • May 2014
                    • 109
                    Thanks - appreciate all the help
                    • di11on
                      • May 2014
                      • 109
                      Hmmm... I have an interesting dilemma... I was told there were three grades of grog, namely:
                      Extra fine: 002
                      Fine: 005
                      Coarse: 015
                      I assumed that was 0 to 2mm, 0 to 5mm and 0 to 15mm
                      I bought a bag of "Fine" and a bag of "Coarse".
                      I'm now looking at my sacks of grog and they say 0.5mm and 1.5mm!!!
                      Arrrgggg...
                      Is there anything I can do with these? What could I add as a coarse aggregate? I really don't want to lug those 50kg sacks back and start my search all over again!
                      I would be grateful for any suggestions!
                      • Tscarborough
                        • Oct 2009
                        • 3341
                        Get a canvas bag and some brick and start pounding.
                        • di11on
                          • May 2014
                          • 109
                          Does it need to be firebrick that I pound?
                          I was originally going to go for a mix something like:
                          48% Grog 0-15mm
                          30% Sand
                          22% Refractory cement
                          Any suggestions as to what ratio I would then mix the following components:
                          Grog 0-0.5mm
                          Grog 0-1.5mm
                          Pounded Brick
                          Sand
                          Refractory cement
                          • Tscarborough
                            • Oct 2009
                            • 3341
                            The fine grog should replace a portion of the sand.
                            • di11on
                              • May 2014
                              • 109
                              Thanks TS,
                              I'm guess there really isn't any benefit to having the two grades of fine grog, but I assume there will be some benefit to using one of them to replace the sand as you say?
                              Putting the question another way, if I'm going to have to pound brick now anyway - will the fact that I have a bag of 0-1.5mm grog mean that I will have to crush less brick than I otherwise would have had to (if I had no grog)?
                              Can I get away with non-refractory brick?
