Greetings everyone-
About a year ago, I asked for and received some fantastic advice about converting a steel wood burner I found to a WFO. The thread is here: http://www.fornobravo.com/forum/f43/...ion-18785.html
Unfortunately, other things arose and I never got to it. But now I'm going to start the project. Before going to too much trouble, I'm going to give it a test run just to get a sense of whether it will be worth the effort. Here is the oven:
http://www.fornobravo.com/forum/memb...-img-0132.html
http://www.fornobravo.com/forum/memb...-img-0133.html
To close up the opening of the floor, I bought two steel plates:
http://www.fornobravo.com/forum/memb...-img-0134.html
The fire brick goes on top of them. If this goes well, I'll eventually insulate underneath the oven and all of that.
http://www.fornobravo.com/forum/memb...-img-0138.html
Then, I'm lining the walls with more fire brick.
http://www.fornobravo.com/forum/memb...-img-0140.html
Oh, and of course, I'll close up the chimney on top.
http://www.fornobravo.com/forum/memb...-img-0137.html
So I'm wondering about what the experts think so far? One little concern is that I'm cutting off the depth of the oven a little with the bricks on the wall in back. I could cut more fire bricks so as not to lose that much of the hearth, but I'd only be gaining another inch and a half. Does that matter?
Thanks in advance!
Jeff
Thanks in advance!
Jeff
