Temporary chimney
  • jinsko
    • Jan 2013
    • 32
    Temporary chimney
    Hi Everyone-
    Winter is coming and I'm hoping to use my newly built (but not yet finished) oven even during the cold months. But since we don't have time to do a real exterior until spring, we built a temporary shelter out of treated plywood (pics below).
    I expected some smoke blackening, but what I (stupidly) didn't quite expect was that the front of the plywood would burn from the heat that escapes through the chimney vent-- oops!
    So now I'd like to build a fast, cheap, temporary chimney. But I'm not sure what to use to do it. Anybody have any clever suggestions? The arch with the vent in it (pic below) is a steel plate that I had fabricated.
    Thanks in advance!
    Jeff
  • shuboyje
    • May 2009
    • 406
    Re: Temporary chimney
    All you need is some basic black stove pipe from the local hardware store.
    • Mitchamus
      • Aug 2008
      • 389
      You can make one out of dry stacked bricks.
      It's not safe, but it satisfies you requirements for fast, cheap and temporary
      here is a pic from my thread:
      My 2nd Build:
      Is here
      • jeeppiper
        • Mar 2011
        • 321
        I think I would go with stacked bricks; might be a bit tricky with the arch though. You could maybe get some concrete board and rig a rectangular duct.
