Steel lined oven. Help please.
  • wadedc
    • Mar 2014
    • 2
    I am going to start building an oven with steel liner and steel outer shell with about 8-10 inches between the two filled with rocks and sand to retain heat and then insulate over that. Is it better to have the inner liner thin like 1/4-3/8 steel to let the heat get to the rocks or I have 1" thick material if that would be better?
    Thanks for any advice.
    Wade
  • halfbakedpixel
    • Dec 2011
    • 19
    Re: Steel lined oven. Help please.
    I'm just about to build a Vault oven using a 12mm thick mild steel half tube, then brick over the outside. I'll try and keep you updated.
    • v12spirit
      • Nov 2011
      • 466
      If the unit of 1/4-3/8 is inches, it would be fine. see Wiley's oven. It has pretty close to that layer of steel. Mine (under construction) is even 2 mm thick steel too. I guess it will outlive me. It is surprising that 1 inch of steel takes longer to heat up than 1 inch of bricks when considering volumes, because steel is far denser even it is more conductive. If I were to exploit steel in my oven to conduct heat, I wouldn't go thicker than necessary just to support the weight of thermal mass. 10 mm max I guess.
      BTW isn't 8-10 thick layer of rocks too much of thermal mass or you have special design intentions?
      I forgot who said that.
      • wadedc
        • Mar 2014
        • 2
        Got my 42" diameter propane tank domes.
        [/IMG]
        • TropicalCoasting
          • Dec 2011
          • 408
          looks like Dolly Partons Bra
          • jrwalker
            • Feb 2014
            • 7
            Wade
            1/4 inch is fine , you want the heat to penetrate to the thermal mass and heat that up as soon as possible.
            I would think 10 inches of sand would take a very long time to heat up , i would use no more than about 3 or 4 inches , with an insulating layer around that , it would heat up quicker and the insulation layer would hold the heat.
            Are you using both domes as outer and inner shell , or do you have another plan ?
            • texman
              • Nov 2009
              • 724
              interesting project. Looking forward to your progress.
              Texman
              Texman Kitchen
